Farmall Tractors Discussion Board
Re: Re: Converting a B to an A
Posted by Stan(VA). on June 29, 1999 at 19:30:49 from (207.172.106.29):
In Reply to: Re: Converting a B to an A posted by Harold H on June 29, 1999 at 17:38:47:
You will also need to use the grill from your A when you switch the front bolster. And your right rear will still be 4" wider unless you have a BN, but hopefully the wide front will adjust enough to cover it.
Stan(VA).
Post a Followup
: Re: Re: Re: Converting a B to an A
