Farmall Tractors Discussion Board
Re: Re: Will a Wide FE from M fit an H?
Posted by Jim on June 30, 1999 at 15:23:30 from (199.240.128.77):
In Reply to: Re: Will a Wide FE from M fit an H? posted by Wayne on June 30, 1999 at 14:52:50:
The front pivot is the same.The turning arm needs the holes cut out about an 1/4" to 1/2" or I might have an arm for you depending on front brand. The rear mount is 2" wider on an M You can build an extention each side.If you have any questions email me.
Post a Followup
: Re: Re: Re: Will a Wide FE from M fit an H?
