Re: Sleeves and Rings
Posted by MN Scott on March 23, 2009 at 17:57:16 from (206.9.216.88):
In Reply to: Sleeves and Rings posted by Bud W on March 23, 2009 at 10:35:46:
Do some pricing, I'll bet new sleeve-piston- ring kits will be cheaper than ordering individial sleeves and a ring set. Aluminum pistons wear at the same rate as rings and sleeves, if your sleeves are out of round you can bet your pistons are worn to fit them. Putting old pistons in new sleeves will result in a poorer fit than you have now and worse oil consumption.
