Farmall Tractors Discussion Board
Re: Will a Wide FE from M fit an H?
Posted by Harold H on June 30, 1999 at 17:07:53 from (207.244.9.70):
In Reply to: Will a Wide FE from M fit an H? posted by Jim on June 30, 1999 at 12:52:36:
Jim,
Most aftermarket brand wide front axles had various holes in the brackets and steering arm where they would fit different models. If your axle is a aftermarket brand there is a good chance that it will fit. The on IHC wide front axle, the axle itself is the same but the steering arm, main pivot bracket, and rear mounting bracket are all different. The holes in the steering bolster (where the tricycle front mounted) are closer together and the M frame is about two inches wider than the H. You may be able to make adaptors or blow holes or such and get it to fit, but it will not bolt on as is off the M.
Harold H
Post a Followup
: Re: Re: Will a Wide FE from M fit an H?
