Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Super A battery charging
Posted by ltf in nc on June 30, 1999 at 17:32:17 from (206.228.213.41):
In Reply to: Re: Re: Re: Re: Super A battery charging posted by Mark B. on June 30, 1999 at 14:45:41:
Mark, lets try to get the tractor to charge then I will help you tidy up everything. If time permits I would like for you to do the following:
A..take all the wires loose from the alternator
B..Run a 12 gauge or larger wire from the Batt. terminal on the alternator to the amp gauge
C..From the other terminal on the amp gauge run a wire to the + terminal in the battery
D..From the batt. terminal on the Altenator run a 14 gauge wire to the number 2 terminal on the side of the alternator. This should be the terminal the greatest distance from the batt. terminal CONTINED ON NEXT POST
Post a Followup
: Re: Re: Re: Re: Re: Re: Super A battery charging
