Farmall Tractors Discussion Board
Re: Farmall Super C - Replacement Rear Axel Housing
Posted by Phil Auten on July 01, 1999 at 05:57:13 from (206.175.72.226):
In Reply to: Farmall Super C - Replacement Rear Axel Housing posted by Kevin Bentley on July 01, 1999 at 04:49:40:
Kevin,
If you have a Super C, it will be a '51 - '54 model. If it's a C it would be a '48 - '51 model. There were C's and Super C's produced in '51. If you get the serial number off the plate riveted to the box below the seat you can look up the year in the serial number reference on this site or on Alan Moore's page at the link below.
http://www.sckans.edu/~alan/tractsn.html
As for the axle housing, try looking in the yellow pages for tractor salvage yards, try to find out about tractor shows and/or swap meets in your area, or if you're lucky, someone will respond with a good housing for you. I believe that the C and Super C used the same housing so that should make it easier, as they were pretty popular tractors. There were over 178,000 produced.
Phil
Post a Followup
: Re: Re: Farmall Super C - Replacement Rear Axel Housing
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
