Farmall Tractors Discussion Board
F-20 gear noise
Posted by Farmall Gray on July 02, 1999 at 06:46:02 from (152.163.201.79):
My F-20 makes a lot of gear noise when under power
but is fairly quiet when coasting. I suspect it has a bad bearing (or several) somewhere. I have to put wheel seals and brakes on it so I will have that apart soon, but I suspect the problem
may be one of the transmission bearings. Are there
any particular bearings that are prone to failure
on an F-20? It is a '39 on rubber with high speed
gears and it has been in use all its life so I
guess there's no shame for it.
Post a Followup
: Re: F-20 gear noise
