Farmall Tractors Discussion Board
Re: TD9, questions
Posted by Harold H on July 04, 1999 at 18:23:07 from (207.244.8.159):
In Reply to: TD9, questions posted by davids on July 02, 1999 at 22:03:58:
I can't find crawler serial mumbers but your TD9 tractor has to be 46 or earlier, I would guess by the low number 39 or early 40's. The Trac-Trac-Tor name was used thru the 46 model. It was not used on the 47 model. The Bosch injector was also used thru the 46 model. The 47 model had a IHC pump.
Harold H
Post a Followup
: Re: Re: TD9, questions
