Farmall Tractors Discussion Board
Re: Super M brakes bind when in reverse
Posted by Bob M on July 06, 1999 at 09:13:58 from (205.188.192.167):
In Reply to: Super M brakes bind when in reverse posted by Joe Berendzen on July 06, 1999 at 06:37:25:
Joe -
Presuming you've got disk brakes, remove the cover/disk assemblies and check the following:
1 - Loose/broken friction mat'l on the brake disks
2 - Oil-soaked disks
3 - Worn internal splines
(Find any of the above, then replace all (4) disks...)
4 - Disassemble and clean the intermediate disk ass'y. Be sure the ramps and balls are smooth - lube with a little powdered graphite.
5 - Clean (wire brush) the male splines on the differential half-shafts. Check for wear (notches) in the splines. Badly worn splines will result in erratic brake operation and binding.
6 - Lightly lube the male splines w/ Never Seez or gun grease - wipe off any excess. Also clean and lube the dogs on the intermediate plate ass'y and the mating surfaces inside the cover.
7 - Thoroughly clean all the iron braking surfaces (on the tranny, the intermediate plates and inside the cover) w/ brake cleaner - need to remove every trace of oil from these surfaces.
Good luck!
Post a Followup
: Re: Re: Super M brakes bind when in reverse
