Farmall Tractors Discussion Board
Re: Power Steering???? Help please.
Posted by steve on July 06, 1999 at 12:46:53 from (153.4.57.6):
In Reply to: Power Steering???? Help please. posted by Bob Bearsch on July 05, 1999 at 14:54:49:
Are your belts slipping at higher engine speeds? Have you
called and discussed this with a hydraulic shop? You might
have to put a gauge in line and see exactly what is happening
with the pressure. Are you using the correct hyd. fluid?
Most hyd. pumps put out less pressure at lower speeds, so
your problem is indeed odd.
Steve
Post a Followup
: Re: Re: Power Steering???? Help please.
