3 of them. The needle fails to seal on the seat either from a hair or flake of junk, or from a slight imperfection in the needle or seat. (old worn needles and seats leak from the fact that the seat and needle have a very wide contact ring that allows any slight accidental needle misalignment to upset the seal)
The seat could be leaking where it is screwed into the body.
The float could be touching the bowl binding and not floating. Float drop specification keeps the float from going low enough to touch the carb body/bowl. If it does touch when no fuel is in the carb, it can stick and never float at all.
Always shut off the fuel when shutting off the tractor, just make it a part of the process each time. It is a gotta do on gravity fed systems, they can fill a barn with fuel in 20 minutes. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
