Re: Somma u guys come up with the dangest worrys
Posted by Dave H (MI) on March 24, 2009 at 07:08:23 from (64.12.116.73):
In Reply to: Re: Somma u guys come up with the dangest worrys posted by LMack on March 24, 2009 at 06:28:42:
I'm sorry, don't know what an Ag-engineer is, but I think you are just plain wrong. Three points on the ground is more stable than four. Take your camera tripod and a table with four legs out into your field and see which one sits stable most consistently. There was a study done years ago, and I wish I still had the link, at one of the major midwest universities on this topic and the tricycle tractor won out by a slight margin. I found this link when I was first looking to buy a tractor. At the time I was pretty worried about moving to a tricycle from the wide fronts I was used to. Experience taught me that this worry was unfounded and that both are safe tractors if used safely. As for the Farmall B? If stability were the reason for it's discontinuance then I think they would have immediately dropped narrow fronts on the other tractors in the line. Of all the narrows, the B sits lowest and has the widest stance for it's size and weight. After many hours and multiple uses, I consider this model to be one of the safest...once again, if used safely. IMHO
