Farmall Tractors Discussion Board
Re: Re: Tips on removal/replacing H water pump without pulling the radiator
Posted by The Red on July 09, 1999 at 12:40:29 from (206.246.187.2):
In Reply to: Re: Tips on removal/replacing H water pump without pulling the radiator posted by al on July 09, 1999 at 11:39:42:
al stick the nut back on and give it a good pop. This is my 4th or 5th. water pump and those tapered bolts are just plain stubborn.
Another idea is get a piece of one by hard wood and drill a hole that is larger than the head on that tapered bolt. Stick that over the bolt head, stick on your nut on the threaded end and use a C clamp to squeeze that tapered bolt out.
Good luck. They are frustrating indeed.
Post a Followup
: Re: Re: Re: Tips on removal/replacing H water pump without pulling the radiator
