Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: tractor support?
Posted by ro on July 09, 1999 at 17:57:01 from (205.188.199.184):
In Reply to: Re: Re: Re: Re: tractor support? posted by don on July 08, 1999 at 10:50:53:
I agree with wood blocking. You'll probably find enough of these lying along the road to be able to build up your solid support. I've supported a TD-18 Dozer this way-they are solid, just be sure to either use large blocks or do a double crossing stack arrangement, sort of like shoring anything else. You have to anticipate that you may be doing some tugging and prying on the tractor with the wheel removed, so just be sure its solid. A little overkill for safety will be worth the extra time to make it solid.
Post a Followup
: Re: Re: Re: Re: Re: Re: tractor support?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
