Farmall Tractors Discussion Board
Re: Super M hydraulic level
Posted by Bob M on July 09, 1999 at 19:05:03 from (152.204.187.197):
In Reply to: Super M hydraulic level posted by Dale on July 08, 1999 at 07:25:54:
Dale -
Is your hyd reservoir IH factory stock live hydraulic style (square cast iron tank located under the back end of the fuel tank)? If so, there should be a 1/2" elbow and filler pipe nipple on the left side of the tank.
Don't know what the level should be (original filler cap and dip stick are long gone). I fill mine by idling the engine and listening to the pump. Add fluid until you stop hearing air in the pump (the pump stops growling), then add about 1 qt more. Add too much fluid and it simply spits it back out the filler cap. Probably not the correct procedure, but it's worked for me for many years...
Post a Followup
: Re: Re: Super M hydraulic level
