Farmall Tractors Discussion Board
Re: Re: Re: 560 hyd. valves
Posted by ro on July 10, 1999 at 17:51:14 from (205.188.192.187):
In Reply to: Re: Re: 560 hyd. valves posted by Jim on July 10, 1999 at 07:26:51:
Hello,
Did you get my e-mail which stated that my manual says that only the highest (furthest from the ground) hydraulic coupling should be used for single acting cylinders, with the valves set for single acting. This applies to both the right and left side pair( beneath the fuel tank) and the rear set, in which case the top connector is to be used.
Post a Followup
: Re: Re: Re: Re: 560 hyd. valves
