There are no complex parts or special tools required, do it your self! It just come apart. take pictures and clean up the components. New dicks are likely needed. Clean the ball tracks and balls (new balls can be purchased (for the expanders) The only machining would be if the cover, expander, and inside surface are worn dramatically. Then the cover can be machined to allow it to move closer to the tractor casting. (amount to be determined carefully). There are many Disk Brake entries and photos in the archives. Normally takes 1.5 hrs per side. Sand the metal friction surfaces with 250 grit non directionally. Use a tiny amount of Triflow PTFE dry lube on the pivot points, and splines, do not get it on the disks or friction surfaces. JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
