Farmall Tractors Discussion Board
Re: Re: Re: Re: Corey's 51H at 33 hours. Head bolts and valve clearance report.
Posted by The Red on July 12, 1999 at 06:58:39 from (206.246.187.2):
In Reply to: Re: Re: Re: Corey's 51H at 33 hours. Head bolts and valve clearance report. posted by Milan on July 12, 1999 at 05:50:38:
Mine were tight Milan. I suspect on the last adjustment I got the timing mark slightly pass TDC on #1 so I adjusted against a cylinder not at full psi. I'll check it again around hour 60 to make sure.
Post a Followup
: Re: Re: Re: Re: Re: Corey's 51H at 33 hours. Head bolts and valve clearance report.
