Farmall Tractors Discussion Board
Re: Re: Engine block for Farmall Super C
Posted by Stan(VA). on July 13, 1999 at 06:01:37 from (207.172.109.164):
In Reply to: Re: Engine block for Farmall Super C posted by Tim B on July 12, 1999 at 17:38:08:
It depends on what you need and where you're at. I bought a stripped down block that I used my own crank, rods, cam and head on for $250 from a salvage yard. I added a new sleeve kit, bearings, and valve train. I ended up with as much money in it but ended up with a new head too. It all depends on what you've got to start with, and how much you want to put in it.
BTW - the 354898R1 is the Super C block casting number. You will find it behind the oil filter.
Stan(VA).
Post a Followup
: Re: Re: Re: Engine block for Farmall Super C
