Re: H carb rebuild question
Posted by Theman on March 24, 2009 at 12:27:34 from (63.107.135.35):
In Reply to: H carb rebuild question posted by Jim Isler on March 24, 2009 at 10:43:44:
The carbs on both of my H's have the ball and spring you are describing. If the ball doesn't compress flush with the hole, there's crud in the bottom of the hole or you have too much spring. Also, be sure to use the new felt seal around the choke rod in the housing. Now, if that spring flies out and goes on vacation to parts unknown, a BB will work just fine in its place.
