Farmall Tractors Discussion Board
Re: Farmall H Oil Pan
Posted by Bob M on July 14, 1999 at 11:09:48 from (192.232.120.193):
In Reply to: Farmall H Oil Pan posted by John Gulley on July 14, 1999 at 10:45:28:
The double petcock setup I presume is a carryover from the era of distillate burning engines. These suffered from oil dilution on account of unburned fuel getting past the rings while in operation.
Procedure for the start of a days work:
1 - Open the lower petcock until oil stops draining.
2 - Close the lower, then open the upper petcock.
3 - Add fresh oil until it appears at the upper petcock.
4 - Close the upper petcock - your crankcase is now full and ready to go.
Post a Followup
: Re: Re: Farmall H Oil Pan
