Farmall Tractors Discussion Board
Re: Update on Super A another ??
Posted by ltf in nc on July 14, 1999 at 12:49:38 from (206.228.213.196):
In Reply to: Update on Super A another ?? posted by Raymond(MO SA) on July 14, 1999 at 06:37:49:
The Red and Big Fred have covered most of the bases. However, since you are removing the plugs, mark which cylinder each is removed from. Examine each plug very closely for variations from the others. This may indicate where the whitish smoke is coming from. If you heard a sucking noise when you loosen the gas cap you had a vent problem. Otherwise, you just created time for some fuel to seep back to the carb. and your fuel lines are clogged at the tank outlet or somewhere prior to the new filter ( the new filter could also be clogged) Good luck
Post a Followup
: Re: Re: Update on Super A another ??
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
