Farmall Tractors Discussion Board
Re: Re: Radials for an A
Posted by Kev in Iowa on July 14, 1999 at 13:55:04 from (207.177.4.47):
In Reply to: Re: Radials for an A posted by Larry on July 13, 1999 at 18:10:29:
Thanks for the response. Four proablems with fluid. it's hard to get remove, it prevents the tire from laying down it's foot print, it can rot your rims, a 24 inch rim doesn't hold enough to make the diffrence..I have 100 lbs front suitcase weights I can make brakets for to mount..
Let me rephrase my intent, I want to run in the field with a 1 row male corn planter when it is to wet for larger equipment. also en Aug. use a tool to destroy Male corn after it's done polinating. Right now a hyclear unit does it but he knocks down to much female corm..
Post a Followup
: Re: Re: Re: Radials for an A
