Farmall Tractors Discussion Board
Re: Radials for an A
Posted by Farmall Gray on July 14, 1999 at 15:18:36 from (152.163.201.76):
In Reply to: Radials for an A posted by Kev in Iowa on July 13, 1999 at 16:47:35:
Would it help to raise the drawbar on the tractor?
This will transfer some of the weight of the implement to the tractor. This would give the same effect as adding balast and will make the
implement easier to pull.
Post a Followup
: Re: Re: Radials for an A
