Re: F340 12 volt conversion
Posted by Janicholson on March 24, 2009 at 13:56:15 from (199.17.6.128):
In Reply to: Re: F340 12 volt conversion posted by Earl Gordon on March 24, 2009 at 13:41:54:
If you click on them, they expand to very visible (my system) Either is fine, an Alternator is more reliable, and tops the battery with precision. But it is not stock looking. If youu look at the archives here you will find 3000 entries about putting alternators on farmalls. Yours will be the same as the upper right diagram with a relay based starting system. JimN
