Farmall Tractors Discussion Board
Re: Re: Radials for an A
Posted by Larry on July 15, 1999 at 08:05:27 from (206.228.213.170):
In Reply to: Re: Radials for an A posted by Larry on July 13, 1999 at 18:10:29:
Certainly it is your call and I have read your intent in your last post. I only partially agree with the fluid problems. Antifreze will not rot your rims. The foot print with fluid or without fluid is more air pressure related than fluid/no fluid effect. To accomplish your task could you run a wider/larger tire? (Requires a rim change) This will give you more area for fliud and the foot print would grow along with floatation. The only benefit that I have seen from radials is in traction with a major load to the tractor. In wet conditions the radial I have do not clean out as well as the non radials. I will not pay the premium for radials in the future as I have been disappointed with there performance. I did not get the value preceived for the value spent. Good luck
Post a Followup
: Re: Re: Re: Radials for an A
