Farmall Tractors Discussion Board
41 A Brakes Thanks You!
Posted by Doug (VA) on July 15, 1999 at 19:52:38 from (216.12.54.61):
With advise from several of you I was able to pull right side axle housing and axle. My mistakes were not enough WD 40 and not prying hard enough. Top and bottom axle housing dowel pins and brake dowel were rusty as you advised.
Have not attempted to reassemble. I plan to replace all bearings and seals on the back end so it will be a while.
As for balance when jacking rear of A the owner's manual advises placing a block of wood between left bottom of radiator and front axle. I did this and it seems to work.
Thanks again.
Post a Followup
: Re: 41 A Brakes Thanks You!
