Farmall Tractors Discussion Board
Re: Super A Pulley
Posted by Stan(VA). on July 17, 1999 at 12:48:39 from (207.172.109.165):
In Reply to: Super A Pulley posted by Mike on July 17, 1999 at 09:06:37:
Get a bearing splitter that goes behind the pulley to distribute the force, then get a large 2 jaw puller big enough to hook behind the bearing splitter. It takes alot of force to pull that thing, so get heavy tools. If you try a standard 2 or 3 jaw puller applied to the lip of the pulley all you do is destoy the pulley and it doesn't move.
Stan(VA).
Post a Followup
: Re: Re: Super A Pulley
