Posted by D Slater on March 24, 2009 at 17:54:10 from (72.65.131.58):
In Reply to: need some advice posted by N.D. Farmall H Puller on March 24, 2009 at 17:03:40:
It would be hard to answer your question with any certainity. To give a ballpark answer would need the height of piston top above or below deck at top of travel. How far heads of valves are from head surface. Total valve lift. Thickness of compressed head gasket. Last if things are close you would need to know relation of valve opening to piston position and relation of dome shape to valve position. You will be able to see all the parts and know what you have. Probably the simplest thing is to put the head on with the old gasket if thats the type you are using agian, set valve clearances and turn engine and check with clay on pistons or a dial indicator with weak springs installed on valves. Check several degrees before and after TDC if using dial indicator method. When checking turn engine slow and stop if contact is felt.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
