Farmall Tractors Discussion Board
Re: Re: Re: Need verification of proper fueling procedure on Farmall H
Posted by Joe Berendzen on July 19, 1999 at 10:32:48 from (164.89.253.3):
In Reply to: Re: Re: Need verification of proper fueling procedure on Farmall H posted by The Grounded Red on July 18, 1999 at 16:46:26:
Them "static lines" has done been incorporated into the fuel delivery hose at the pump and provides a ground to dissipate any static charge - PROVIDED that you have the nozzle in contact with the metal rim of the filler on the tank. The biggest hazard in fueling a running vehicle, especially one with the tank directly over the distributor and exhaust manifold is: If you let it run over, or spill some, it runs right down to an ignition source. Then you have to re-paint whats left of your H.
Post a Followup
: Re: Re: Re: Re: Need verification of proper fueling procedure on Farmall H
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
