Farmall Tractors Discussion Board
Re: Super A PTO
Posted by Rick K on July 21, 1999 at 09:55:19 from (205.181.231.254):
In Reply to: Super A PTO posted by Hugh on July 20, 1999 at 18:59:59:
Bad bearing is good possibility. Tow behind PTO driven implements, whcih the Super A is designed to use, would probably tend to be harder on bearings than 3 point implements, due to what happens when you make a corner. I know that when mowing with my tow behind brush hog, things get a little noisy past about 30 degrees of turn. While hard on u-joints, it can't be good for the PTO shaft bearings either.
Post a Followup
: Re: Re: Super A PTO
