Harold, you aren't going to get any fewer answers here. They'll just be condensed into one thread to confuse you even more.
First off I recommend that you get yourself a reprint manual for your tractor. That will give you the original oil types and capacities so you're not guessing.
Second, anything labeled "gear lube" is the "right" oil for the rear end of your H. That could be SAE90, SAE85W140, or any of the other various thick-weight gear lubes.
Frankly anything liquid and slippery will work. The tractor just isn't that fussy. You could use "hydraulic/transmission fluid" and be fine, but the transmission will be noisier than it should and you'll spend a whole lot more money. People will call me crazy, but technically even vegetable oil would do the job. You'd just get sick of the rancid smell after a few months.
Drain as much of the old lube as possible, THEN put in the kerosene and run the tractor around. Drain again, and refill with new lube of your choice.
Just don't do the kerosene treatment to the engine. Some poor fellow did that and actually ran the engine and drove the tractor with kerosene in the crankcase. Siezed the engine and at the very least ruined the bearings.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
