Farmall Tractors Discussion Board
Re: Super A Questions
Posted by Jim Becker on July 22, 1999 at 15:37:15 from (209.30.184.141):
In Reply to: Super A Questions posted by Tim B on July 22, 1999 at 08:35:25:
You probably have an A-189 2 way plow, but may not have all the correct mounting parts. Check with Binder Books for a manual. It is used as you were told, use one bottom one way, then the other going back.
The unit you describe on the rear of the tractor is a rear rockshaft assembly and was used with various mounted equipment but was not a standard part of the tractor.
Post a Followup
: Re: Re: Super A Questions
