Farmall Tractors Discussion Board
Re: Found a Super A Problem
Posted by Kev in Iowa on July 23, 1999 at 08:07:00 from (207.177.4.240):
In Reply to: Found a Super A Problem posted by Raymond(MO SA) on July 23, 1999 at 07:48:11:
Can you tell why it bent? Two thoughts a tappet wey out of advustment, something fell down the manafold and then the motor was cranked. One more, motor sat to long some time and the valve stuck in the valve guide.. Any of these makes on think maybe if the tractor has set awhile it might be better to pull the head to check it out instead of causing more damage. Hope yours only needs a new valve and maybe a guide. One could check if the valves are free just by pulling cover and with a lever push each down to check free movement..
Good luck.
Post a Followup
: Re: Re: Found a Super A Problem
