Farmall Tractors Discussion Board
1944 Farmall H Wiring
Posted by John on July 25, 1999 at 07:25:11 from (205.183.16.121):
Can someone help with a wiring diagram of the electrical system of a 1944 Farmall H. I think a previous owner may have rewired some things or there may be a short to ground somewhere. If I could trace out the wiring I can repair the damage. It has a generator and voltage regulator. Plus coil and points ignition. Six volt battery.
Thanks
John :)
Post a Followup
: Re: 1944 Farmall H Wiring
