Farmall Tractors Discussion Board
Int 706 L
Posted by Richar Henninger on July 25, 1999 at 17:14:01 from (205.188.200.24):
I have an International 706 L, Serial Number 2224 S-Y that uses propane. I was trying to plow yesterday and the tractor ran good till I bogged it down. After that it would die every time you tried to open the throttle. It would start up and run at low RPM. I limped back to the tractor shed and unhooked the plow and parked the tractor. Before I cut it off I tried to open the throttle and it ran fine. I attached a blade to try and do a little work on some roads. The tractor ran fine for a while but the problem returned and finally it would not restart.
Any ideas. I am going to replace the points, condensser, rotor button and distributor cap. Do you think that that will help. How can you tell if the engine is gettting propane. This is my first experience with a tractor, and I am a little lost.
Thanks
Post a Followup
: Re: Int 706 L
