Farmall Tractors Discussion Board
Re: Cub engine races out of control
Posted by bronco on July 25, 1999 at 21:34:17 from (206.150.162.154):
In Reply to: Cub engine races out of control posted by Todd on July 25, 1999 at 15:11:21:
Could be the govenor control rod that is connected to the carb. Pull the rod to fast idle and see if you feel the govenor trying to pull it back, if so it's the rod connection adjustment, if it doesn't pull back, it's the govenor!
Post a Followup
: Re: Re: Cub engine races out of control
