Farmall Tractors Discussion Board
A Couple Super AV ??'s
Posted by Raymond(MO SA) on July 26, 1999 at 06:51:37 from (209.176.153.105):
Did the Super AV series have a different serial number sequence? I was working on mine this weekend had my book out and decided to really see which model year it was. The Serial #63255 threw me. The Super A '47 model year has a 253000 number as either the first or last for that year, but either way I thought only 94,000 were even made. So, is it a '47 as the Super A serial # or did the SAV have a diiferent sequence? BTW, the serial # is complete on the plate.
Also, is it possible or likely that this tractor was not suppost to have a head gasket? Did not think so. When I pulled the head, I was inspecting it, looking for a bad place in it & saw no gasket material, thought maybe it was stil on the block. However, both were clean metal.!?!.
Also found a bent rod. That is another question. I have not found a specific place that lists the Rod. I found valves & the like but no rod. Can you guys help there too?
Thanks
Post a Followup
: Re: A Couple Super AV ??'s
