Re: Farmall 450 clutch problems
Posted by mkirsch on March 25, 2009 at 11:14:11 from (64.80.108.55):
In Reply to: Farmall 450 clutch problems posted by rustyfarmall on March 25, 2009 at 10:49:36:
Yup, your clutch and TA adjustments are WAY off.
There is a return spring for the clutch pedal that should pull it back to the platform. There should be over an inch of "free play" in the clutch pedal measured straight off the platform if it is adjusted properly.
The tractor should only "stick" on a hill with the clutch pedal halfway out. If it won't roll with the pedal completely depressed, the TA clutch is not releasing and it needs to be adjusted.
This is a very specific process that is detailed in the owner's manual, in the I&T service manual, and the IH service manual. Do it wrong and the TA won't work. Worst case you end up burning out the TA clutch, as what happened to my Dad's W400 before he bought it. It was adjusted wrong.
