Re: Re: Re: I should know this!!!
Posted by Dave_Id on January 26, 2002 at 14:43:53 from (63.20.49.184):
In Reply to: Re: Re: I should know this!!! posted by fordson29 on January 26, 2002 at 13:58:20:
There is an engine ser.# on the milled flat above #1 sparkplug. Engine prefix on the A is FAA, and on the B, is FAB. The ser.# originally matched on the A's and B's before any swaps were done. It must look really weird with a narrow front and no left rear axle. Another thing, the A had a real heavy cast right wheel, and the Bs right axle was stamped metal.
Post A Followup
: Re: Re: Re: Re: I should know this!!!
