Re: Re: Compression Readings on 300U
Posted by Robert on January 27, 2002 at 18:59:41 from (64.158.52.147):
In Reply to: Re: Compression Readings on 300U posted by erkel3 on January 27, 2002 at 18:38:11:
Thanks for the advice. I just had all the valves replaced. I set the valve lash and rechecked it. I used to work on aircraft engines when I was in flight school. I remember that if you had a reading of or around 70Lb (80LB gauge setting) per cylinder that was pretty good! I am leaning towards taking the front of the engine off to look at the gears.
Thanks
Robert
Post A Followup
: Re: Re: Re: Compression Readings on 300U
