Re: Pre-Paint Primer Type
Posted by steve on January 27, 2002 at 19:16:44 from (204.246.222.22):
In Reply to: Pre-Paint Primer Type posted by lcbateman on January 27, 2002 at 13:06:12:
Im gona sound a little like a beginner, but i really like a fast drying, red oxide primer that you can get at Farm store for $20. gallon. I realy like a brand called PANDA mad in St Louis, Mo., but there ae others. I use it to prime bare metal, and rusty metal after i have gone over with a wire brush. I do this with implements that i spray on $25 enamel top coats, and tractors that i spray on $200 Dupont enamel. When i restore a tractor i brush on the red oxide to each part as i get it cleaned (axle housing, transmission, etc) after every thing is bolted together i sand it with 150 grit by hand and then spray a coat of the red oxide if needed. Sand with 220. After no brush marks or scratches i spray the Dupont. Use hardener to get glossy and dry faster.
Post A Followup
: Re: Re: Pre-Paint Primer Type
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
