Re: ih 414d compression
Posted by Kurt on January 29, 2002 at 16:23:54 from (63.212.146.177):
In Reply to: ih 414d compression posted by JT on January 29, 2002 at 14:43:35:
I checked the compression on my H when I bought it and it was between 85 and 90 psi. and the place to check it was to remove the spark plug and thread in a compression check fitting and a gage, about $40 or so. leave the coil off and crank the engine with the starter and watch the pressure climb up, then it should hold the pressure then release and move onto the next cylinder.
Post A Followup
: Re: Re: ih 414d compression
