Farmall Tractors Discussion Board
Re: 966/1066/1466/1566 question
Posted by SDman on July 27, 1999 at 21:44:50 from (63.65.237.219):
In Reply to: 966/1066/1466/1566 question posted by Ben on July 27, 1999 at 18:11:04:
.Ben, I'll try to answer your questions. As far as engines go; the 966 used a 414 with no turbo(986s used a 436, not the 414), 1066s used a DT-414, 14 & 1566s used DT-436s. 966s had a smaller diameter clutch than the turboed models. The axles, axle bearings, & bull gears were smaller on the 966. 966 also had just a Cat. II 3pt hitch, 1066 had a Cat. III hitch. As far as differences in rear ends from a 10 & 1466, the brakes were bigger on 14s, I think there were other small differences that I can't recall now. As far as the 1566,that rear end was quite a bit different, only 12 forward gears, different TA, & planetary final drives with larger axles instead of the bull gear final drives.
Post a Followup
: Re: Re: 966/1066/1466/1566 question
