Re: Re: Re: Re: F-12 Oil Pan
Posted by walt f on February 01, 2002 at 17:58:04 from (24.159.79.106):
In Reply to: Re: Re: Re: F-12 Oil Pan posted by F14,,,Hey, Mike on February 01, 2002 at 17:08:20:
my f-20 has three petcocks on the side of the oil pan, little one on the bottom and top and big one in the middle. on the f-20 you have to pump oil into the gits oilers on top of the valve cover every four hours while in use. the large petcock is provided as a spigot for this purpose (to fill the oil can)
Post A Followup
: Re: Re: Re: Re: Re: F-12 Oil Pan
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
