Farmall Tractors Discussion Board
Re: 966/1066/1466/1566 question
Posted by kev in Iowa on July 28, 1999 at 05:49:21 from (207.177.4.202):
In Reply to: 966/1066/1466/1566 question posted by Ben on July 27, 1999 at 18:11:04:
On the 1586 it is a major job to fix brakes, the on we had was "fixed" every 18 months, not a good record. I do not know if this was common or just our normal luck. It also had brearings go out in the trans and one set of main crank bearings changed on oil test results...
The good part is the 86 type cab is far better than the 66, and the seat finally moved forward for a better ride and easer to get in & out. the 66 was just some better than aftermarket cabs. When we traded up from a 1466 to the 1586 I didn't miss the 1466 very long!!!!!!!!!!!
Post a Followup
: Re: Re: 966/1066/1466/1566 question
