B Farmall charging system
Posted by Mark B on February 02, 2002 at 10:06:15 from (199.120.106.212):
I have a B that possibly could be wired incorrect. I just had the generator rebuilt and when I put the charging rate on High or Low the tractor will die immediately like shutting the switch off. If you run the switch like the lights are on dim or bright the tractor runs fine. Any thoughts...Thanks!
Post A Followup
: Re: B Farmall charging system
