Re: Re: Re: 300 U clutch
Posted by Robert on February 02, 2002 at 10:08:06 from (169.139.63.243):
In Reply to: Re: Re: 300 U clutch posted by John W. on February 02, 2002 at 09:03:51:
John, there are a host of things that could be wrong. I had trouble with my clutch about two months ago. There was almost no disengagement with the pedal all the way down. I looked through the bottom inspection cover and saw that the clearance between the pressure plate fingers and release bearing was excessive and uneven. I split the tractor and found that only one third of the plate had been making contact. I searched for new parts and found that it was cheaper to have mine rebuilt (didn,t replace anything after all was said and done). Put tractor back together and adjusted everthing back out. Seems to work fine now. I think that adjusting the fingers out helped the most on mine.
With the pedal all the way up I adjusted the fingers so that there was 1/8' between their face and that of the release bearing. Then adjusted all of the linkage. That means TA too. I hope this helps you. I didn't really have any destroyed parts maybe you'll be lucky
Post A Followup
: Re: Re: Re: Re: 300 U clutch
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
