Re: Cub HELP
Posted by Rodger on February 03, 2002 at 05:42:12 from (167.127.100.47):
In Reply to: Cub HELP posted by Justin on February 02, 2002 at 17:45:03:
Justin, I have used a cub for the last 35 years they are great little tractors and should last as long as you take reasonable care of it. Mine is a 1949 and is a 6 volt my brother as an early 50's model which is also 6 volt. Remeber this the 6 volt tractors are hooked-up so that the positive terminal is to the ground....... If you think it is a 6 volt system and connect in the conventional positive to ground manner it will not charge properly and I do not believe it will turn over.. There are also manufacturers that make 8 volt batteries to provide a little more juice without overloading the systems as much as just sticking a 12 volt battery in a 6 volt system it. If it is a 6 volt it is probably stamped into the generator somewhere but it is tough to see the generator without taking the hood off. Good Luck.... Rodger
Post A Followup
: Re: Re: Cub HELP
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
