Re: M clutch
Posted by Haas on February 03, 2002 at 17:32:41 from (129.37.117.220):
In Reply to: M clutch posted by Redrev on February 03, 2002 at 15:30:30:
Is the play side to side or is the rod loose in the hole?? A little side to side play is normal, as there is nothing holding the shaft in there except the fork that moves the throw out bearing. If the shaft is loose in the hole, you might want to consider putting in a bushing, but you will have to go up from under the tractor to take the release fork loose from the shaft in order to get the shaft out, a pretty big job. If there is only a little play and the clutch is working, I would not sweat it.
Post A Followup
: Re: Re: M clutch
